ARUF37C14 GOODMAN MULTI POSITION AIR HANDLER FEATURING SMARTFRAME CABINET
Features- ARUF multi-position multi-speed air handler
- Check flow rator for cooling and heat pump applications
- Direct drive multi-speed PSC blower motor
- All aluminum evaporator coil
- Coil mounting track for quick repositioning
- Optimized for use with R-410A refrigerant
- Cabinet air leakage less than 1.4% at 0.5 in. H2O when tested in accordance with ASHRAE standard 193
- 3kW - 25kW electric heater kits
- Horizontal or vertical configuration capabilities
- Rigid Smart Frame cabinet
- 21 in. depth for easier attic access
- Decca BDE-free thermoplastic drain pan with secondary drain connections
- Screw less sides and back helps to reduce condensation when installed in humid locations
- Foil faced insulation covers the internal casing to reduce cabinet condensation
- Galvanized leather grain embossed finish
- Glue less cabinet insulation retention
- Tool less filter access
- AHRI certified; ETL listed
- Cooling (BTU/h) - 36000
- High Rated CFM - 1375
- Circuit Amps - 4/4
- Max Fuse Size - 15/15
- Voltage - 208/230
- Liquid Line Size (IN) - 3/8
- Suction Line Size (IN) - 7/8
- Filter Size (IN) - 19-1/2 x 20
- Dimensions - 21 W x 21 D x 53-7/16 H in.
Price: 805.87
