GMSS920803BN GOODMAN SINGLE-SPEED 1-STAGE UPFLOW AND AMP; HORIZONTAL LOW NOX GAS FURNACE
Features- Heavy-duty aluminized-steel tubular heat exchanger
- Stainless-steel secondary heat exchanger
- Single-stage gas valve
- Durable Silicon Nitride igniter
- Multi-speed blower motor
- Quiet single-speed induced draft blower
- Self-diagnostic control board
- Color-coded low-voltage terminals
- All models comply with California Low NOx emissions standards
- Designed for multi-position installation - GMSS92 - up flow horizontal left or right
- Certified for direct vent (2-pipe) or non-direct vent (1-pipe)
- Easy-to-install top venting with optional side venting
- Convenient left or right connection for gas and electrical service
- Cabinet air leakage (QLeak) 2%
- Heavy-gauge steel cabinet with durable finish
- Foil-faced insulated heat exchanger cabinet
- Airtight solid bottom or side return with easy-cut tabs for effortless removal in bottom air-inlet applications
- 92% Afue
- 80000 Btu
- 1200 Cfm
- Size - 17-1/2 in.
Price: 1015.56
