GOODMAN 3552948 MULTI POSITION AIR HANDLER FEATURING SMARTFRAME CABINET 2.5 TON
Features- Multi Position Air Handler Featuring Smartframe Cabinet 2.5 Ton
- Equipment should be sized selected and installed by a qualified professional to ensure proper installation safe operation adherence to federal state and local codes and for valid warranty; see installation guide for more details
- Professional installation recommended
- ARUF multi-position multi-speed air handler
- Check flowrator for cooling and heat pump applications
- Direct drive multi-speed PSC blower motor
- All aluminum evaporator coil
- Coil mounting track for quick repositioning
- Optimized for use with R-410A refrigerant
- Cabinet air leakage less than 1.4% at 0.5 inch H2O when tested in accordance with ASHRAE standard 193
- 3kW - 25kW electric heater kits
- Horizontal or vertical configuration capabilities
- Rigid SmartFrame cabinet
- 21 inch depth for easier attic access
- DecaBDE-free thermoplastic drain pan with secondary drain connections
- Screw less sides and back helps to reduce condensation when installed in humid locations
- Foil faced insulation covers the internal casing to reduce cabinet condensation
- Galvanized leather grain embossed finish
- Glue less cabinet insulation retention
- Tool-less filter access
Specifications- Depth: 21 in.
- Heat Kit: Yes
- Height: 53.4375 in.
- Kilowatts: 3 to 25 KW
- Motor Type: Direct Drive Multi-Speed PSC
- Phase: 1
- Refrigerant Compatibility: R-410A
- Tonnage: 2.5 Ton
- Unit Application: Multi-Position
- Width: 17.5 in.
- Weight: 110 lbs
Price: 722.09
