GSZ140481 14 SEER ENERGY EFFICIENT SPLIT SYSTEM HEAT PUMP
Features- R-410A chlorine-free refrigerant.
- High efficiency scroll compressor.
- SmartShift technology to ensure quiet reliable defrost.
- Factory installed bi-flow liquid-line filter drier suction-line accumulator compressor crankcase heater and high capacity muffler.
- High and low pressure switches.
- Service valves with sweat connections and easy access to gauge ports.
- Copper tube and enhanced aluminum fin coil.
- Fully charged for 15 ft. of tubing length.
- Contactor with lug connection.
- Goodman brand sound control top design.
- Steel louver coil guard.
- Heavy gauge galvanized steel cabinet.
- Attractive architectural gray powder paint finish with 500 hour salt spray approval.
- Top and side maintenance access.
- Service ports and controls are accessible while unit is operating.
- When properly anchored meets the 2010 Florida Building Code unit integrity requirements for hurricane-type winds.
- AHRI certified; ETL listed.
- Cooling Capacity(BTU/h) - 48000.
- Heating Capacity (BTU/h) - 48000.
- SEER/EER - 14/11.5.
- Min. Circuit Amps - 24.6.
- Max Fuse Size - 40.
- Voltage - 208/230.
- Liquid Line Size (IN) - 3/8.
- Suction Line Size (IN) - 1-1/8.
- Dimensions (WxDxH) - 29 x 29 x 36-1/4.
Price: 2216.50
