Browse our wide selection of small and big home and kitchen appliances designed keeping quality and reliability in mind. These home appliances are easy to use and make your everyday life much convenient and comfortable.
The full-function remote control allows you to operate each feature from across the room. Unlike a fixed air conditioner unit the honeywell portable air conditioner requires no permanent installation and the smooth-gliding caster wheels provide easy mobility from room to room. What's more the auto evaporation system allows for hours of continuous operation with no water to drain or no bucket to empty (this operation depends on the humidity level at your location).
Features
