PTH153G35AXXX AMANA WALL R-410A PTAC HEAT PUMP WITH ANTENNA AND AMP;44; 14 AND AMP;44;000 BTU
Features- This Amana DigiSmart PTAC heat pump is combined with a self-installable wireless thermostat and occupancy sensor
- This combination gives users complete control over equipment settings and reduces PTAC energy usage by at least 35%.
- DigiSmart control board Technology
- Maximizes Energy Savings
- Tangential indoor fan for provides ultra-quiet fan operation
- Pullout filters for easy cleaning
- 7-Button touchpad design for best and easiest operation
- Easy-to-clean condenser coil with removable shroud
- Room freeze protection
- 20-Amp (6-20P) Plug
- Cooling Capacity - 14000/13900
- Heating Capacity - 13500/13300
- EER - 10.5/10.8
- Cop - 3.0/3.0
- Volts - 230/208
- Amps - 6.8/6.8
- Moisture Removal (Pt/Hr) - 4.4
- CFM (High/Low) - 340
- Electric Heat - 3.5KW
- You can easily install this PTAC unit with a wall sleeve
- It fits industry-standard 42 in. x 16 in. sleeves.
Price: 1143.18
