WHYNTER ARC-12SDH WHYNTER ECO-FRIENDLY 12000 BTU DUAL HOSE PORTABLE AIR CONDITIONER WITH HEATER
Whynter is going GREEN! With this new Eco-friendly CFC free lead free and high enery efficiency portable air conditioner you can stay cool while keeping with better environmental standards and reducing energy consumption.
This Whynter GREEN ARC-12SDH portable air conditioner features the ECO-FRIENDLY CFC free GREEN R-410A refrigerant and lead free RoHS compliant components.
This unit features the patented advance auto drain technology which uses and recycles moisture collected during the cooling process to produce cool air. The dual hose operation provides fast cooling.
Frost White color.12 000 BTU Cooling.11 000 BTU Heating. Dual hose operation. ECO-FRIENDLY CFC free GREEN R-410A refrigerant.Lead free RoHS compliant components. Patented auto drain function fully exhausts all condensate automatically in most environments. Three operational modes: Air conditioner fan or dehumidifier. Digital and remote control. LCDI (Leakage-Current Detection and Interruption) plug.Dehumidifying Capacity: 96 Pts / day. Designed to provide quiet and efficient cooling to any room with no permanent installation.3 Fan speeds. Carbon air filter and washable pre-filter. Full thermostatic control (61 F - 89 F). Casters for easy mobility. 24 Hour programmable timer. Noise level (dBA): <56. Auto restart after power outage. Extendable exhaust hose (up to 49). Upgraded Plastic window kit included. Window kit length: Max. 36. Refrigerant: R-410A. Air Flow (at high speed): 320 m3/h. Maximum cooling power consumption: 1100 W / 10.5 A. Maximum heating power consumption: 1020 W / 9.5 A. Power supply: 115 V / 60Hz / 1 Phase. UL Listed.Dimensions: 20 W x 34 H x 16.5 D.
Price: 609.49
