Specifically equipped with an internal condensate pump that can be activated when using the heat function the Whynter ARC-148MHP portable air conditioner is especially useful in high humidity conditions. The unit can be easily setup in almost any indoor location and is most commonly used in data closets / server rooms bedrooms classrooms and garages / workshops. The Whynter ARC-148MHP portable air conditioner provides 14000 BTU cooling and 11000 BTU heating output while maintaining a compact and portable profile. The dehumidifier mode allows you to extract 71 pints of excess moisture during a 24-hour period. The Whynter ARC-148MHP will never cause you a spill over. When the water tank is full the compressor will shut down and will not start back up before the tank is emptied. Alternatively the AutoPump function can be utilized to pump out (and up) condensate moisture through the included 16.5 ft. drain for continuous water removal with approximately 15 ft. of vertical lift. This unit also features a separate dehumidifying mode that enables it to be used as a room dehumidifier as needed. A 3M Filter and SilverShield washable pre-filter are equipped standard on this air conditioner to help keep the cooled air cleaner and fresher. Equipped with a remote control that can easily control the speed temperature timer and dehumidifier settings even from a distance the Whynter ARC-148MHP also comes with rolling casters that will allow you to move the portable air conditioner room to room.
Features
